Garmin GPSMAP 431...Remote Operation Possible?
pbolden
Hello Everyone,
I have a GPSMAP 431. It has a simulation mode in which to learn the units functions. I would love to spend several hours doing this. The manual suggests that you can take the unit inside and run the simulation mode but as far as I can tell, Garmin doesn't give you a way to accomplish this (i.e. batteries, external power supply or adapter). Am i crazy or did Garmin just have a bad day while writing this manual LOL?
Thanks,
Paul Bolden
StingrayMike
Its for use if the boat is inside a building for storage, but you can buy an appropiate 12vdc power supply and hook it up to that. We use Stinger power supplies, i would think there are cheaper out there. Not sure if the price would be worth it, but sure would help learning the equipment instead of on the fly.
pbolden
No Title
Thanks CaravelleMike. I guess it's all in how you read the words...you're right, sure inside storage is what they meant. I was thinking inside the house on the sofa with a beer LOL...GEEZ!
I'm going to buy an additional power/data cable, attach an accessory plug and plug it into a 12v battery pack using this hot and ground wire.
Does anyone see any problems with this hookup?
Thanks,
Paul Bolden
Thanks,
Paul Bolden
I did the same thing. Wired a 12V adapter off an old answering machine to it. Just plug it in. Beat mess'in around a battery pack.;)
