Gas Lines
seawolf
Why are the quick connectors on gas lines so cheap. Mine leaks, do I have to replace it or can I buy O rings for it?
Re: Gas Lines
Ayuh,... Probably just needs an oring...
cr2k
Re: Gas Lines
If it is a plastic fitting I would throw it far away and replace with a metal unit.
If your hose is a Tempo unit I would throw it too. Use a Sierra Silver or OEM.
