Gas Smell on boat After Shut Down
ni7irs
2008 Cruisers 330 with Volvo Penta 8.1Gi engines. V Drive
I have a gas smell after shut down that is pretty heavy. Checked the bilges and found no gas. Any ideas on where to start troubleshooting? Metal gas tanks.
start checking every fuel connection.
then have your tanks pressure tested
Silverbullet555
Include the fuel rail and it's connections when checking. Check the fuel level sender in the tank as well.
ni7irs
Is there anything to the fact that it only occurs after shut down? It usually comes 5-10 minutes later. I see no gas in the bilge.
mklearl
Yeah... you're not moving... no ventilation. Be careful!
