Gas Tank Vent
buddyearl
Are these tanks vented, if so, where's the vent?
southkogs
I can't quite tell from the picture, but the "knob" on top of the fill cap might be the vent.
keninaz
Yep, I agree. It should unscrew (vent) counterclockwise and close clockwise
NYBo
If there are two fuel lines running to the motor, the tank is not only not vented, it's pressurized. With this setup, there is no standard fuel pump on the motor, and one of the lines pressurizes the tank to push gas to the motor through the other line.
