Gasket kit for gm 4.3 omc.
LassePelle
Hi everybody :) I must change my intake gasket, so i desided to change every gasket in the engine. A friend who knows engines has checked the pistons an cylinders and says they look good. No big scratches or anything.
The problem is to find what gasket kit i need. The engine is a 1988 omc 4.3 non vortec. Can i use the same kit as for cars or should i find a marine kit? Been looking at ebay, but there are so many to choose from so i hope someone here can advise me :)
Thank you.
Re: Gasket kit for gm 4.3 omc.
Ayuh,... A Quality set, like from Fel-pro will work, so long as it includes Composite head gaskets...
