gasket sealant
Squab
Can I use this sealant on the Head and Intake gaskets? How about the Fuel and water pump gaskets? Also is there something else that I should use when putting the intake mani back on besides the two gaskets?
Re: gasket sealant
Ayuh,... Why are ya putting it back together,..??
You ain't found the Problem yet....
Btw,... Most gaskets are designed to be put on dry, on CLEAN surfaces...
The Intake manifold is abit different, in that I throw away the end pieces, 'n use Only rtv sillicone...
