Gear Lube for Older Johnson
ScottG76
The manual calls out Hi-Vis or Premium blend. Can I use BRP HPF Pro Gearcase Lubricant? I know it's a silly question and I'm almost positive I can, but I'm new to this and want to make sure I don't screw anything up. Thanks for the help.
seahorse5
Re: Gear Lube for Older Johnson
All mechanical shift J and E gearcases can use the HPF-Pro gear oil.
the electric and the electro-hydraulic shift gearcases need to use Premium Blend, formerly known as Type C.
ScottG76
I'm guessing the code is in the serial number for the motor?
boobie
Post a model # to be sure.
Yes that lube will work perfectly.
You can even use the mercury brands too....... in your motor you are running a marine type gear oil.
82rude
bob ,you know full well the merc gearlube will make his gearcase turn slower,lol.:D
jbjennings
It's easier to change the lube with the johnson blend. The mercury lube requires a special tool to open the container.
-------Yes, I'm working on my Mercury, lately... :mad-new: :)
OMG that's right!!! The other thing to watch out for is do not buy the oil for the "counter-rotating drive" engine ;)
