Gear Lube? Need a straight forward answer.
JNormV163
1991 Sunbird corsair 19' 4.3 OMC cobra Sterndrive. I keep reading all these different answers for what type of gear lube to use in these. I've always had Mercruisers so I just use the Hi preformance 90. I read that you can also use it in these OMC's. Is this true or does OMC command a different oil? Got plenty of Merc gear oil so I'd rather not have to go buy more. Thanks guys.
JNormV163
Thanks, definitely didn't want to ruin anything but I didn't see an issue with using it. Just realized I spelled "high" as "hi" I think I'm getting dumber and dumber. Bummer.
Lou C
I've used it for 10 years in my Cobra and it works great
superbenk
Should be fine. It's gonna be better than anything OMC recommended 25+ years ago.
jerryjerry05
It will work.
OMC used a 75/80 in the Cobra when they first came out.
ANY 90 from any manufacturer will work.
