gear oil running out of prop
misery
So my new to me boat is really starting to look like not such a good deal. Its an 89 peterborough with a 5.7 mercruiser and an alpha one drive. The motor turned out to be bad the gimble housing is junk and now I noticed that the lower unit has gear oil running out of the prop. What are the most likely causes of this. I tried putting a pressure test on it but i didn't have enough stuff to build one. I'll gather up enough stuff to make one on the weekend, but for now i'm just asking to get some input. thanks.
Ayuh,.... It could be any one of several oil seals,.....
