Gear Ratios
yjanray
So I am thinking of getting a new outdrive. My ratio is listed on the housing as 1.65R. I am looking at a new to me out drive that says it is 1.62 and has a 24/24 tooth count. How do I make sure that unit will mount up to my transom with no issues.
Thanks!
Bt Doctur
As long as its a Alpha 1 drive it will bolt up . a Alpha 1 GEN II drive will not. Alpha 1 5 nuts and a allen under the zinc, Alpha GEN II 2 nut has nuts and bolts on the sides
yjanray
The one I'm looking at is a older MC1 drive that was recently serviced and never put back on project boat. It says It has a 1.62 gear ratio but my current drive is 1.65R. Will it work with my motor?
Should bolt right up an not be an issue
kenny nunez
The 1.62 was designed for the 470 engines, however if a boat was to be used at a high altitude then the 1.65 was recommended.
Ayuh,..... 1.62:1, 'n 1.65:1 are virtually the exact same ratio,....
Swappin' a drive to yer I6, you'll need the shorter input shaft, vs: the normal longer shaft used on motors other than the In-line GM motors, durin' the MC-1 years,....
'n I believe the 470s used either a 1.65:1 for lighter hulls, 'n the 1.84:1 for heavy hulls or higher altitudes,...
yjanray
Can I take the input shaft off of my upper and put it on the new one in an getting?
