Gel Coat
ampedzach
Hey Guys,
I want to change the color on my boat and do some touch-ups and what not. Do I need to sand down the existing gel coat or do any prep work, or can I just apply the new gel coat and do all the finishing?
Thanks!
ampedzach
Re: Gel Coat
Ok, thanks a lot! I think I'm going to paint the whole thing black. I'll post some pics when I'm done.
Thalasso
Re: Gel Coat
If your going to change colors, i would think about painting it with a good marine urethane paint.(Awl grip or Imron) It won't fade like gel coat and will last longer.Having mine done the end of this month.
pauloman
Re: Gel Coat
folks with lots of $$$ have the yard remove the gel coat from their brand new boats. Gel coat is not considered a quality finish.
Generally an epoxy primer and a two part polyester LPU coating (google lpu). Awlgrip is one vendor of LPU and other coatings if you don't mind paying 300% more than they are worth
Yacht Dr.
Re: Gel Coat
Actually Gelcoat is a very durable finish and the repair cost is a fraction of Paint.
I dont know why Anyone would Remove the gel prior to painting. ???
Just to let you know that Gelcoat is a 2 part polyester ;) .. LPU is Linear Poly Urethane ( Nastiest of the Nastiest of paints IMO ). Its Very hard to repair. There is a way to repair LPU but is costly.
A good alternative of a good topcoat paint is Imron or AwlCraft 2000. Very expensive However it is repairable.
With Gel you should give your sanding profile a bit more bite. 120 or 80 grit is best ( I prefer 80 grit for full sprays ).
YD.
ampedzach
Re: Gel Coat
Thanks for the responses guys. I heard this rumor that I could paint the whole boat with some regular paint and then do a clear gel coat over the top to save money. Thoughts?
Re: Gel Coat
Nope,... Ya don't put Gelcoat over Paint...
airman1094
Re: Gel Coat
Yeah putting gel coat over paint doesn't work out well...waste of money...you can use a good marine paint over the existing gel coat...then coat with marine grade clear coat
Yacht Dr.
Re: Gel Coat
Why would you Paint ( I dont know what you mean by Regular Paint ) and not clear over it with the paint system you had ?? Clear over the paint with what you had then sand/buff it out.
YD.
