Gimbal bearing presed in?
Dieter
2002 four winns 4.3 mercruiser alpha one drive. Carrier bearing is out is it pressed in I guess ? Aka gimbal bearing? Thanks
Re: Gimbal bearing presed in?
Look at the amazing info I found in the OEM service manual.
attachment.php
You can download that manual at this link.
http://www.4shared.com/document/dPQUcyn_/Service_Manual_14.html
Dieter
I would if I could. I am posting from my iPhone we do not have Internet at our house yet. Just moved again due to the military
Ayuh,... It's pulled out, 'n Pressed in, Yes...
Dieter
What does the puller look like is there one similar to the one I need at an auto parts store ?
The tool is designed to fit in the center of the gimbal bearing, and push on the outer diameter of the bearing only while staying centered on the bearing while you hammer it in.
You aren't going to find them at an auto parts dealer. Cars don't use them. If you have a NAPA around that sells Sierra brand marine parts, Sierra makes the tools.
http://forums.iboats.com/showthread.php?t=329915&p=3098784&viewfull=1#post3098784
Dieter
Ok thank you sir there is one close I will check it out
