Gimbal Bearing Tight
Beachcraft 1
1977 Mercruiser 228, 350 GM motor
Hello,
Installed a gimbal bearing. Used the proper driver, did not damage the races, yet very tight and won't turn freely. It appears seated up against the grease seal and grease is getting to the bearing. Any thoughts?
Thanks.
Re: Gimbal Bearing Tight
Hello,
Thanks.
Ayuh,... Finish it up, 'n Run it...
