Gimbal housing anode and transom gasket
mwe-maxxowner
I'm in the process of reinstalling my outdrive and motor. I need the transom gasket and the two anode bolts on the bottom of the gimbal housing. In an earlier thread I was given a part number for the transom gasket, but when I enter it into the parts search I don't get anything. When I search for a transom gasket, it only shows one for the Gen two. I have an alpha one Gen one 1.86 ratio.
My anode bolts twisted in two. When I search iboats, the search yields the acorn caps, but I need the whole bolt and everything. I can't find info about them in old threads so far. If I can't find anything I guess I could find a bolt that fills the hole and then add an anode and ground it to the gimbal housing?
Re: Gimbal housing anode and transom gasket
Looks to 1/4 20 and 1.375 long.
1 98869A17 ELECTRODE ASSEMBLY (BLACK) 98869A11 $126.58 $114.12 1
1 98869A14 MERCATHODE SYSTEM (OYSTER) $181.59 $163.70 1
2 10-69067 SCREW, (.250-20 x 1.375), ELECTRODE $1.70 $1.66 2
3 13-26992 LOCKWASHER, (.250) Stainless Steel, ELECTRODE SCREW $0.70 $0.69 2
4 12-29245 WASHER, (.281 x .500 x .060) Stainless Steel, ELECTRODE SCREW $0.80 $0.79 2
Or these show 1/4 20 by 1.5
31 27-988231 GASKET, HYDRAULIC CONNECTOR $1.90 $1.86 1
32 98825A4 MANIFOLD ASSEMBLY, HYDRAULIC (BLACK) $82.30 $76.13 1
33 27-995061 GASKET, CONNECTOR COVER $1.40 $1.37 1
34 10-28636 --SCREW, (.250-20 x .750), CONNECTOR COVER (click here) $1.20 $1.18 2
35 13-78968 --LOCKWASHER, Internal (.250), CONNECTOR COVER (click here) $1.00 $0.98 2
36 13-78968 LOCKWASHER, Internal (.250), HYDRAULIC CONNECTOR STUD $1.00 $0.98 2
37 11-8267119 NUT, (.250-28), HYDRAULIC CONNECTOR STUD 11-13438 $1.60 $1.57 2
38 57322T COVER, GIMBAL HOUSING $9.89 $9.67 1
39 10-28635 SCREW, (.250-20 x .620) Stainless Steel, COVER TO GIMBAL HOUSING $1.20 $1.18 2
40 821631Q1 PLATE ASSEMBLY, ANODIC $24.92 $24.47 1
41 12077 --SEAL (click here) $1.00 $0.98 1
42 27-995061 --GASKET, ANODIC PLATE (click here) $1.40 $1.37 1
43 10-86885 SCREW, (.250-20 x 1.500) Stainless Steel, ANODIC PLATE $1.70 $1.66 2
44 13-78968 LOCKWASHER, Internal (.250), ANODIC PLATE SCREW $1.00 $0.98 2
Ayuh,.... I donno where yer lookin' for the gasket,...
Mercruiser has Both,...
The bolts yer lookin' for are actually aluminum Studs, threaded on both ends, but with a shoulder on the outer end,...
1/2", by 'bout 5 or 6"s,...
mwe-maxxowner
Thanks guys. I typed transom seal into the search here on the iboats store and it only showed me the Gen two gasket. I have found it other places, but iboats always ships fast.
mwe-maxxowner
Is this thing to be used to drive the new gimbal bearing into place? And, can I drive the old bearing out from the backside with a punch and a hammer without damaging anything?
