Gimbal Ring
Jerryh3
While putting the outdrive back on the boat today, I snapped off a piece of the plastic pad that is at the bottom of the gimbal ring. Does anyone know if this piece if replaceable? I looked on mecurypartsexpress.com, but it doesn't have a part number for them.
Re: Gimbal Ring
Ayuh,.... It's a alignment/ torque pad,...
I gotta believe it's replaceable, they come off easy enough...
Jerryh3
Re: Gimbal Ring
Ok. Think I found them. They're actually part of the upper housing and not the gimbal ring. Mercruiser calls them wear pads. Long day.
MarkSee
Re: Gimbal Ring
Buy a couple extras as I've found those will break pretty easy....even new ones.
Mark
