Guys which way round does the shaft seal go the one behind the Gimble Bearing Thanks
T Taz59 Petty Officer 1st Class Joined Apr 10, 2003 Messages 304 Jun 4, 2018 #1 Guys which way round does the shaft seal go the one behind the Gimble Bearing Thanks
D dypcdiver Lieutenant Junior Grade Joined Nov 1, 2005 Messages 1,047 Jun 4, 2018 #2 Lip facing the Gimbal bearing, it is there as a last resort to hold back water from entering the boat if the bellows split. It also stops grease being flung around the flywheel area.
