gimble bearing
larson260
I have a DPS-B 1.95 drive and am having trouble finding the proper replacement gimble bearing in the iBoats web sight under shop. Any help would be appreciated.
Bt Doctur
sierra 18-2100
  • New Gimbal bearing. Replaces GLM Part Number: 21900; Sierra Part Number: 18-2100; Mercury Part Number: 30-60794A4; OMC Part Number: 983937; Volvo Part Number: 3853807-0
  • Fits OMC Cobra and King Cobra
  • Fits Mercruiser Bravo and Alpha Gen 1 and 2. Fits MC-1 / R / MR
  • Fits Volvo Penta
  • This is the grease able type. Your transom must have a grease zerk fitting.
Perma-Lube type. 18-21006
larson260
Thank you for the info, recieved the new bearing today and removed the old one.I have two questions.
1. The Volvo shop manual says on page 220 "Position the gimbal bearing with the ring slots facing in towards shield. When I removed the old bearing the slots were facing out. Which is the right way.
2. Should I replace the gimble bearing seal at this time. If so how does the old one get removed. How does the new one go in, do I need the "special tool". 3850038?
muc
1. Slots should face the bow of the boat.
2. The seal doesn’t have much of a useful purpose with a sealed bearing. I wouldn’t recommend replacement.
