GLM Marine Products
slow joe
Has anyone ever purchased GLM products for their OMC? I found them while searching, and although the closest outlet to me is Chicago, IL it's a possibility for parts if they're good quality parts at a good price. Let me know your thoughts...
In case you haven't heard of them -- GLM Products Inc
Re: GLM Marine Products
We've heard of them . . . very common supplier of aftermarket parts. I cannot speak specifically for the OMC replacement parts, but generally, some of their parts are OK, and others not as good as the OEM versions.
You can get GLM parts through a variety of suppliers.
southkogs
I tend to search for the OEM, but I think I've used a couple of GLM pieces over the years.
GLM = Good Luck Marine
I like OEM myself. What particular parts do you need?
Ayuh,... I bought a set of GLM exhaust manifolds a few years ago,...
I hada have the tops resurfaced, decked, to seal the gaskets to the risers,...
slow joe
At this point I don't need any parts (I will after I pull the engine/outdrive).. I was just trying to get some ideas as to where the best place(s) to get parts for my OMC Cobra would be...
wrench 3
I've had similar problems as Bondo. Had to do some creative shimming with drive parts.
Sierra Marine seems to make a much better product if you can't afford OEM.
slow joe
Yeah, it really isn't a matter of cost, as much as it is knowing what to and not to buy since I'll be removing my outdrive and engine in my Conquest in the next week or so... Just figured if I need some parts I'd start finding sites/companies to order from...
wrench 3
This site sells Sierra parts but the Sierra Marine site has a better catalog for looking up part numbers.
