Gluvit Questions???????
raidercoop
Hello All,
While I was prepping my 14' aluminum V for a primer coat, I noticed a few small (TINY) holes in the hull. I have purchased a quart of gluvit and I am planning on applying it this Friday. I want to put two coats on just to be on the safe side. My question is do I have to use the entire quart in one setting? The directions say to mix a full can of Gluvit catalyst to Gluvit resin. But then it also gives a mix ratio of 5:1 this would lead someone to believe that it can be mixed to amounts that are needed rather than using the entire quart. Since an entire can covers 25-30 square feet, and I only need to cover about 10 square feet. Seems like a waste to mix the enire can. With the area of coverage that I need, how much should I mix? Also what can I mix it in? Can I go to a local home improvement store and use a regular paint tray? Any answers are appreciated! Thanks, Raidercoop!
xtraham
Re: Gluvit Questions???????
mix only what you need, your local marine or automotive paint supply store should have cups with mixing ratios right on the cup they are very cheap............
xtraham is right any auto paint supply will hand you a mixing cup.
I have used gluvit on my aluminum boats and 1 coat is really pretty thick and very adaquate. The gluvit creeps and flows so be sure to only mix a small amount (smaller than you think you need) then you can always go back if you think a 2nd coat is needed. The surface wants to be clean and preferably bare aluminum for adhesion. It seems like it takes forever to dry (over 24 hours).
Bob
