Godfrey AP2422
I have a 1988 Godfrey AP2422 Entertainer. Anyone know the difference between the Entertainer and the Executive Cruiser? We bought it with just a homemade bench seat, in the rear. We are looking into pontoon seating and I am curious to see what the factory layout was. My railings are all the way back with a 3' deck up front. I have seen restore projects and sale ads of other Godfreys similar year set up the same, but they are all Executives. I noticed under mine there are holes indicating the railing was once located farther forward. I would love to put it back there and gain a little more room for seating inside but the fuel tank would cause a hiccup. It has an aluminum tank with filler and vent mounted in the fence. I assume this is the factory setup. Moving everything back forward means moving the tank too. Than means either the tank under the seating which I am not thrilled about or I loose most of the extra seating gained by enclosing it in a "storage" compartment. I realize there are other options available to retain the fuel tank in its current position, I am just curious on what the original setup was. Any info would be appreciated, Pictures would be excellent. Thanks.
No help for the post, love your user name. Guessing your a Bob and Tom fan
lncoop
Have you asked anyone at Godfrey? They might be able to help you out.
