Grady White 206G, Bracket,Trim question
xmurray
I recently purchased a used 86 Grady White 206G with a 92 Yamaha 175 on the Grady Drive bracket. The boat rides great and planes nice especially at full speed around 40 mph. But at even slightly slower speeds the stern really plows down deep into the water, so much so that the water is nearly touching the engine cowling even when trimmed as best as possible. I was wondering if this is a known problem due to the heavy motor being so far off the back of the boat and if anyone has any suggestions. Would trim tabs be the correct way to fix this? I checked the mounting of the motor and it is all the way down and appears to be set very close to the Grady suggested mounting. Any suggestions would be greatly appreciated.
Re: Grady White 206G, Bracket,Trim question
Tabs are highly recommeded on all Gradys,
Sea Mitch
I recently bought a Grady. When I was comparing boats I emailed Grady quite a bit. They were great at getting back to me and very helpful. Try going the gradywhite website and asking them this question. They were even familiar with the Yamaha engines and how they intergrate with their boats. http://www.gradywhite.com/top.fs.php3
xmurray
Thanks, I'll check with Grady and also look into the trim tabs. Sounds like they would definitely be a benefit.
