Grandpa's Old Shotgun
atx111
Looking for some advice on my grandpa's old shotgun. It's a Western Field
Re: Grandpa's Old Shotgun
Ayuh,.... What sorta Advice,..?? What gauge,..?? Pump,..?? break-open, single shot,..?? semi-auto,..??
atx111
Sorry guys. This is what happens whenever I try and do anything on the computer when I'm home alone with my 2.5 year old twin boys. I was in the middle of the post when one of them needed help. The other one climbed up in the chair and was typing away when I came back and must have somehow made the post.
Anyway, it's a Western Field pump action 12 gauge. Looks to be about a 30" barrel. Pretty heavy gun. It's in decent shape for an old farm gun that saw plenty of use. Most of the blueing is gone and the stock was cracked and repaired with a couple of screws. My dad says it'll fire, but gets jammed trying to chamber another round. I've had it in my safe for the 15 years I've had it, taking it out once or twice a year to run a bore snake through it with some new oil and putting it away. I've never attempted to tear it down because I'm afraid of stripping screws and not figuring out how to get it back together.
It's a nice looking gun with the checkered stock and engraving of a dog pointing on the receiver. I know the gun isn't worth much monetarily, but has quite a bit of sentimental value. So my question is this: Should I keep on doing what I've been doing with it and just clean/lube the parts I can get to? Should I find a reputable gunsmith to take it down and do a thorough cleaning? Or should I really get crazy and do a total restoration on it? Thanks for the input and sorry for the lame first post.
Cofe
Some Western Fields were made by Mossberg. Does your shot gun look like this...if it does, it would be the same as a Mossberg model 500.
atx111
No, doesn't quite look like that. The safety is right in front of the trigger and the barrell is stamped Browning patent too. I'll try and get some pics later today.
Google Stevens 520 shotgun and see if those images are closer or look up a Westernfield model 30
atx111
Yup. Looks like it's a Model 30. So do I just keep cleaning it the best I can a few times a year? Should I find someone to break it down for a good cleaning? Or go crazy with a restoration? I don't intend to use it, just want something to pass to my kids.
gm280
You could always research it to see if it holds any huge sought after value. It not then either continue doing a cleaning a few times or go for a complete refurbish. It is all entirely up you. If it has any real collector value then don't touch it will anything to refurbish it. It will subtract form its value...
I love the winter for firearms stock projects. I would have it taken apart by a gunsmith (if it is above your level and it can be or look up a video on youtube and decide if you want to tackle it)........ Gun Parts Corp aka Numrich Gun Parts might have a part that you may need but it should be a labor of kindness over time.
Pull the stock off and repair the stock with some epoxy and get rid of those screw repairs. I have repaired many stocks with epoxy and even epoxied in some pins and wooden pegs inside for added strength (I rebuilt a shotgun stock that was missing a chunk of wood as big as your hand but was later painted to hide that repair). I would spread open any cracks and feed in epoxy and clamp. Not real hard work ;)
Then it becomes your choice on what you want to pass along to the children. Do you want it to just function or look good too? The most money you would be spending is with the gunsmith. A new recoil pad can be installed by you for under $30 but.... refinishing the gun either in blue or with a new high tech coating will cost the most. Not needed but it's your choice.
atx111
I think at the very least, I'll have a recommended gun smith go through it for me. I'm not afraid to strip and clean any of my other firearms, but they're all newer and I have manuals for reference. I'm pretty sure I know how to strip this gun, I'm just afraid of stripping screws or not getting things back together right. I think it's a pretty gun, but its a beast for sure. It might be fun to do a full restore and have it look like the day my grandpa bought it.
I've tried to do the best I can with cleaning and lubing the bore and parts of the chamber I can get to. Got a bore light the other day and don't see any rust in it. I just want to make sure it'll last for a lot longer.
