Grease question(s)
reimelss
Ok i have a read a bunch of different things but i want to confirm...
Gimbal bearing:
Can i get away with wheel bearing grease or do i need to use gimbal bearing grease?
OUtdrive:
Wheel bearing grease or should i use spline grease?
thanks for the help in advance
Re: Grease question(s)
Gimbal bearing and ujoint grease, and spline grease is specified by Merc, if you don't want to use what is recommended, the follow Bond-o's signature line.
reimelss
Thanks..thats what i figured...
I catch myself saying bonds line more times than none...lol
Ayuh,... About the only grease I Wouldn't use in those 2 applications is Merc's 2-4-C....
