grease
57lawney
while getting boat ready for summer,was greasing all the zerks on the 40 hp johnson ,after completing this went to change cartrige in grease gun then found it was marine grade wheel bearing grease. any harm in this?
JB
Re: grease
Nope. All ahead, full.
BassBlaster29
Re: grease
I use Green Grease for everything. Its waterproof and compatible with all other kinds of grease. Don't ever have to worry about changing cartridges. Its a little pricey but its good stuff. You can get it about anywhere.
http://www.greengrease.net/
Re: grease
I use marine trailer wheel bearing grease for everything. It is the best for every usage on an OB, and the trailer as well.
