GREAT FISHING, BAD TIRES
Will narrower tires fit on my rims? Going smaller would be fine with me if it will work.
Why would you go with a 195 LT tire when there are 205 LT tires? problem with LT tires is that you typically can't get the same load rating of a ST with a D rating. Even compared to C it may be lower.
I would also not go with a 70 series tire. Stay with a 75 series. You want more sidewall height...not less!
san dimas
Pep Boys has Kendas' ST 205 75 R14 LRC for 89.99 ea. and they are offering 30% off. So 62.99 ea. Maybe they'll mount them for free. Are these good tires?
oldjeep
Are they Bias or Radial? I use the Kenda ST 205 75 R14 in a D load range radial and haven't had any issues with them.
oldjeep
Likely because there are very few sizes available in 14" LT tires.
JASinIL2006
I have those exact tires, too. I've had them a little more than a year, logging over 4000 miles, and they've been fine. I wouldn't hesitate to purchase another set.
jbetzelb
I had Maxis and liked them. So much I decided to try to get a 5th year out of them. That was an error. 900 mile round trip and I got within 90 miles of home before one split a belt. I would have bought them again but I decided to try a set of Kuhmo 857's. They have the 2271 pound load limit. They cost $300 for the pair mounted and balanced. Time will tell but best case they will get replaced after the 4th year.
naturelover
Ah, sorry! Missed the most important part of it I guess. 😟
Sounds like my luck though, I need like four spares, lol.
Usually dry rot gets my tires, I don't think I've ever actually wore one out....
