hard shift when engine is not on???????
jordan23
I am now getting a hard shift only in forward, when the engine is off... when I start the engine up the hard shift goes away???? should I be concerned ??? rev is fine with the engine off ,just forward....... please helllllllllllllllp!!!!:mad-new:
Joe Reeves
Re: hard shift when engine is not on???????
Deleted, info not required.
jordan23
How would I of fixed the numerous issues on the engine ,without using the shifter lever ,forward or reverse..With it off sometimes..example .. adjusting the throttle cable or unjamming the spark advance etc....... have to disagree with u..anyway hard shift is fixed ..greased the spring more in the throttle arm....Is fine now..
Chinewalker
You got lucky, that's how. You cand disagree all you want, doesn't change the fact that About half the time, the cogs will align correctly. So, if it shifts when not running, it's by chance. As mentioned above, avoid shifting when not running.
kenmyfam
Joe sums it up perfectly. Take heed.
Joe Reeves
jordan23
Please ....ps. My engine works great!!!except for the truninon nut adjustment..Rebuilt the entire engine ..Rebuilt a 55 yr old boat along with the 84 70 hp.. That's not luck ....No need for me to take heed ....Joe is that your engine, in that picture of yours?? huh?? EDIT
All you did was put unnecessary grease there. What happened was that the forward gear and clutch dog just happened to be aligned so that the clutch dog could slide forward. Without the engine running it's just a matter of chance whether or not things are lined up to allow the engine to shift into gear. As already mentioned, if you must shift into gear without the engine running you can rotate the prop to get the clutch dog and gear into alignment, then it will slide into gear easily.
EDIT
