Have scraped the rudder and slightly bent it.
Thales14
How bad is that?
I assume it can have an effect on gas mileage and ultimately steering.
But it's only slightly bent.
If it actually breaks off sometime, is that something that a mechanic can weld back on?
Any thoughts are much appreciated.
Oshkosh1
Ensign
Re: Have scraped the rudder and slightly bent it.
I'm going to assume you mean the "Skeg"...or the lower vertical "fin" on a sterndrive unit.
If it were a true rudder then...
How bad is that?
is REALLY bad...
but just the skeg is not a real big deal unless it's REALLY bent.
If it breaks, it can be welded, or a new one can also be put on.
emoney
Plenty people operate without one. Usually pretty easy to find a welder (instead of a mechanic) to fix it, or weld back a new one if it breaks off. Some folks say they don't even notice a difference in steering. Only way for you to find out is put it in the water and have a go at it. Proof's in the pudding, as they say.
Of course, that's assuming Oshkosh is on it and you're talking about the "Skeg". If it's truly a rudder problem, then "Houston...we have a problem"
Thales14
Skeg fin it is.
Thanks.
I feel better about it now.
Expidia
Local Welder. $50 each time. Ask me how I know this . . . Twice :eek:
