Head ID
love1u0
I picked up a new manifold according to my 3.0 serial# and it doesnt line up right. Doing a little research on the web it looks like my head is from a 2.5ltr.
Can anyone confirm or dispel this from the pictures, as I cannot locate a casting number on the head.
Pic I found on the web:
Re: Head ID
Ayuh,... By the pictures, it appears you're Right....
Put it together,... It'll run Just Fine....
love1u0
Re: Head ID
Well, thats the problem. I have gone through two gaskets that match the new manifold and they both leak. I will attempt to get a gasket that matches the head. But Im not sure if I need to scrap the whole thing and buy a manifold for a 2.5ltr.
Is the head stock or did somebody have issues, and they replaced it with a 2.5ltr head?
zbnutcase
Re: Head ID
Couple of years ago I replaced a freeze cracked 3.0L from a late 80s Cobra and it too had the 2.5 style head. And as the customer bought boat new, engine had to leave GM factory that way. 'nutcase
Howard Sterndrive
Re: Head ID
maybe put some grease on one surface, slide them together and then look at the pattern and see if a 2.5 gasket will solve it.
Re: Head ID
Ayuh,.... The Casting # should be on the top, under the rockers...
Yes, get a gasket that matches the Head....
Before you bolt it back together,....
Check Both surfaces with a straight-edge....
I'm not sure the Spec, but there should be little to No deviations from Dead Flat.....
love1u0
Re: Head ID
Well I just got back from the marine shop and picked I up a gasket for a 2.5ltr and it matches the head perfectly, part#18-2896 replaces Merc/OMC #27-52546/311068.
Im guessing the head is not stock...am I losing performance with this head?
That is the first thing I did after the first gasket leaked Bond-o, thanks
for the suggestion.
Re: Head ID
Donno,... It might be 1 of the Better... Exhaust ports look Good...
It'd depend on combustion chamber volume,+ valve sizes....
Seems the exhaust manifold would be the Choke point of flow...
zbnutcase
Re: Head ID
You are losing performance. The late 8-port head is vastly superior to any of the early heads. Worth the swap? Would be if you could get an aftermarket manifold for it..Mercury only at this point...$ 'nutcase
