Hel[ Me With These Numbers Plse
eurolarva
Re: Hel[ Me With These Numbers Plse
Neither one of those numbers tells anything. Is it a force, seaking, chrysler, wards?
Don't know what those numbers are.
Neither are a model or serial number for a Force.
The only place the numbers are located is on the id tag, located on the starboard transom mounting bracket, or inside the cowl under the bottom carb.
Perhaps a photo or description would help to narrow it down.
Number of cylinders?
number of carbs?
Color of ignition coils?
bluethunder01071973
number of carbs?
ok here are some photos
OK, we are talking about an older Chrysler, 3 cylinder, 3 carb, with a distributor.
I wish I could be of more help, but these are before my time.
Rough estimate is 1976-1979 era.
steelespike
If we are lacking id numbers check the carbsc for model number stamped on flange the 90 uses a WB-21-A The 90 appears in 74-77 and83-84.Became Force in 85.as only an 85hp.
bluethunder01071973
the carbs have wb-9a stamped on them. hope that helps
