Help 85' mercruiser wont accelarate!!
BrandonK
My dads 1985 mercruiser 4 cylinder starts fine,but takes a few for it to accelarate.When it does accelerate it starts to bogg out:confused:?Any ideas what this could be?
nola mike
Re: Help 85' mercruiser wont accelarate!!
time for a carb rebuild or accelerator pump. do a search for accelerator pump on the forums. also, take a look into the carb barrel as you pump the throttle (engine off is fine)--you should see 2 streams of fuel "peeing" into the carb.
Ayuh,... Could you be alittle more Specfic,..??
