Help 97 3.0 gsmlkd carburetor identification.
justinteoc
I purchased the boat last year and ran it a few times and have had good luck besides the minor things I had to replace like the sea water pump and the intake/exhaust manifold but other than that the engine runs good so I decide to give the engine a good tune up and get it ready for this summer so I removed drive greased, checked gimbal bearings, did compression check replace plugs, wires, dist. Cap, rotor, and so on and so forth. We'll I get to the carburetor and decide to tear it apart and buy a kit mainly to clean in good( by the way I'm a diesel mechanic so I half *** know what I'm doing) we'll I remove the carb and get to looking and find that it's a motocraft 2bbl 2150 carb, ( thought it was odd to have ford parts on a gm engine but I figured marine?? Ok ) well I get to looking for a carb kit but I can't find any matching numbers? So I believe someone has put a automotive carb on it? So my question is did motocraft make a marine carb? Also the only numbers I can find on it are D7AE-KA ( does this tell anyone anything) and also if this is not acceptable for a marine engine does anyone know where I can find the correct carburetor? I would even be happy with a good used one but I would like a holley or equivilant. Thanks ahead for the advice!
Fun Times
justinteoc
Re: Help 97 3.0 gsmlkd carburetor identification.
No my carb does not look like that and I can not believe someone put this crap on the boat I mean carbs can pretty much always be rebuilt I just do not understand why someone would take the holley off. Thanks for the help I will definitely be looking for a used one. Edit: Sorry justinteoc, but for safety reasons, posting any personal contact information such as email address, home address, home phone numbers, etc. on iboats forums is not permitted along with soliciting any type of personal transactions.
http://forums.iboats.com/forum-rules-guidelines/forum-rules-397820.html
Hope you get it running safely, Good luck.
http://flyingfishcarburetors.com/Marine-Boat-merCruiser-Rochester-OMC.htm#volvopenta
