Help finding parts
wtx
I have a atwood surge brake actuater #85778 with 10" disc brakes on 03 trailer. I need new master cyclinder for disc brakes . I have found many sites listing parts for #85730 85740 and other actuators but can not find them for my #85778 model. Are all disc brake master cylinders the same or ??
Silvertip
Re: Help finding parts
Try your local NAPA or other major auto parts store.
wtx
Thanks guys. had a hard time finding the right master cylinder. Seem there was a change on the newer ones. The PDF posted helped
I can buy a complete actuator from pacific trailer dot com with free shipping cheaper than buying all the parts from iboats or champion
wtx
Also if you study the master cylinders most are for a 4 bolt 4 1/2 wheel. I have a 5 bolt 5x4 1/2. Most of the sites don't post this or know the difference or if there is a difference
A master cylinder doesn't care what wheel you have.
That will always be the case.
MTboatguy
Normally it is always cheaper to replace than repair when you have to rebuild one..
Lindeman23
What did you end up doing? I'm about to do the same thing.
