Help ID a mercury v8 gm distributor
dohcdelsol93
Came with a box of goodies in a parts boat i purchased. Wanting to know if i can use it to replace the points distributor on my volvo pents 305 v8, im assuming i need a hotter coil and igniton module
dohcdelsol93
I have more pics but says they are too large to post. Took all the pics with the same phone....i suck at computers.
dohcdelsol93
[No message]
email the pics to yourself which will ask you to reduce them....reduce to 25%
then they will be small enough to post.
do you have the ignition amplifier portion of it?
dohcdelsol93
This is the extent of what i have. I believe it was from a boat that was either storm or winter damaged then parted out after a season or so. Still looks new. None of the parts in this box go ttogether. From Bennett trim tab motor to single bbl carb to this, just random parts.
Bt Doctur
what makes you think electronics are better? Points are very simple to service
dohcdelsol93
Points are a pita compared to solid-state. Keep an ignition module and a coil in your glove box, you're covered. No need for feeler gauges, fingernail file, 100 dollar bill or dwelll. Set your timing and forget it. Hotter spark, less maintaince.
if this isn't the hei or marine equivalent ( maybe this is thunder bolt?) And requires the pricey little computer I'm gonna toss it on eBay or a hard sale. Ill replace my points before spending 300 on a dizzy, i was only going to upgrade if i only needed a few simple parts.
Ayuh,...... It appears ya got an '80s, or '90s T-Bolt distributor,......
An important part, but yer missin' to much of the System, for economical use,....
Guessin' a brand new Delco Voyager would be cheaper,....
