Help ID Boat (pic)
jajeeper
I bought this recently. I know it is a 1975 16ft. Astroglass bass boat, but does anyone know if there is a model name? Also, the identification tag is gone so does anyone know what the specs are, such as max. weight and horsepower or is there a generic formula to calculate these? <br /><br />I'm hoping maybe someone out there has her sister.<br /><br />I have used it almost every weekend since I got it, but plan on making it my winter project and extending and rebuilding the fishing decks and compartments.<br /><br /><br />
Trent
Re: Help ID Boat (pic)
1975 Astroglass.<br />Model STD163<br />Beam 6'10"<br />Net weight 1,000
BMDODGE
on NADAguides.com they have it as;<br />Length: 16' <br />Model Name/Description: STD 163 <br />Boat Type: Outboard Boats <br />Hull Material: Fiberglass <br />Beam: 6' 10" <br />Engine: N/A <br />Net Weight: 1,000<br />hope this helps... what size is that merc ???<br />Bruce
jajeeper
Thanks...I don't know why I didn't think of going to NADA. The Merc is an 85HP.
jajeeper, The decals on the Merc look like it is a 1977 model. You may want to verify using the serial number of the motor.
jajeeper
What about max. weight it can carry for equipment and persons and max. horsepower?
BMDODGE
my brother in-law has similiar bass boat - <br />it has on tag;<br />4 persons or 600 lbs.<br />max hp = 85
