Help Identifying some stainless props
Josh P
I need some help, I aquired some props from a friend,(Given to me as payment) four stainless props to be exact. I need to figure out what they fit i would like to sell them. i have a pair to a twin drive set up and 2 of the same with weed cutters... any help is appreciated
Up first the pair.. they have numbers but i cant not cross them to anything..
Josh P
Re: Help Identifying some stainless props
the next two are the same i have numbers, i just wanted to get an idea of what they fit. The info i found was that these are a mercury racing prop with weed cutters...the number on these is, 48-75768-20... please help me thanks again
steelespike
Diameter and pitch would help.
It appears no through hub exhaust,seems to indicate a through hull exhaust and high performance.
48 75768 "small ear inline chopper.
If they are all 15 spline they probably fit bigger Mercruisers. Maybe you already knew that.
Josh P
i will measure the diameter when i get home. there is no stampings other that what i pictured so i really dont know how to tell pitch. They are all 15 spline, the chopper props i believe what i found is that they are 14" x 20 pitch.. thanks for your help..... any more help is appreciated
Ayuh,... The propshaft is the same on the Mercury mid-sized gear case outboards, the large gear case outboards, 'n the Alpha series, 'n the Bravo 1s....
The mid-sized gear case outboards usually swing 'bout 13"s....
The large case, 'n I/Os from 'bout 14" to just under 16"s...
Yer twins appear to be 17", 'n the other a 20"...
The 20" looks alot like an ole Spinnelli chopper prop I've got,...
26" pitch, 'n a cracked blade, it now lives in a Fishtank...
Josh P
All the props are 14'' diameter, the "chopper props" are 20 pitch.. not sure on what the first pair are as of pitch.. bondo thanks for your info, are these props really worth anything besides in the bottom of a fish tank for decor?
Huh,..?? it says P-17,.... I'd think that's Pitch- 17"s....
I'm sure they're worth something to somebody....
The reason mine is in the fishtank is the cracked blade, no way to weld it, 'n believe it'll be reliable, 'n not break off...
