HELP ME FIND BASS TRACKER EMBLEMS !!!!!
WHITEBOYY32
CAN ANYONE HELP ME FIND BASS TRACKER EMBLEMS FOR A 1994 PRO-18? I CALLED TRACKER AND THEY SAID THEY ONLY GO BACK TO THE YEAR 2000. ONE SIDE OF THE BOAT I BOUGHT HAS A SCRATCHED UP STICKER WHERE IT HAS RUBBED UP AGAINST SOMETHING. DO THESE STICKERS STILL EXIST ANYWHERE? WHERE DO I FIND THEM??????
D
DJ
Guest
Re: HELP ME FIND BASS TRACKER EMBLEMS !!!!!
Why nbot get the 2000 stickers and update your boat.
bounder4465
Any sign shop can create them for you. All they do is take a digital photo of the good decal, and import it to their program. From that they can print one, or cut one out of vinyl. The cost will be equal or less than the OEM decals.
Old Jarhead
Second the sign shop suggestion.<br /><br />I've used a local sign shop several times for re-creations with excellent results. BTW. The cost was well below OEM.
I'll Third the sign shop suggestion.<br /><br />BTW,<br />Welcome to iboats........<br />And,<br />Please Loose the CAP-LOCK.........<br />No Need to Holler.........
bounder4465
You can check with Jamie at Interstate Sign Supply. His shop is outside of London KY. If he does not have the time,(He races in the Busch Series) he will know of someone in the area that can help you with your decals needs.
