Help Me Please
bluethunder01071973
im very new to this all and i just bought my first fixer upper boat. but problem after problem, im tring to get it registered with my state. i bought the boat from north carolina and its a 1969 glassmaster tri hull 17' and has a (what ive been told) 90hp force 3cyl and ive never heard it run yet. but have been told it does. i would like to know what it is and maybe a serial number or model number so when i go to shop to get parts i wont look stupid. plse help someone with great intentions. I cant upload the pics i have and would send to the person that can help me so e-mail me and give me ur e-mail address to send them to.
Re: Help Me Please
Hmmmmm.
Well, it looks to be a Chrysler Force.
I'm not to familiar with these older models, but since it has a distributor, and 3 cylinders, and 3 carbs;
I can only narrow it down to one of the following,
a 1975-76-77 90 hp,
1 1977- 83 85 hp
or a 1975-83 75 hp
Look around inside the motor, under the carbs for a model or serial number.
It may look like 906BB, 850HID, or 752hb
I wish I could be of more help, but perhaps someone else can id it from the photo.
bluethunder01071973
Re: Help Me Please
Hmmmmm.
a 1975-76-77 90 hp,
1 1977- 83 85 hp
or a 1975-83 75 hp
Is there anything that i can cross check to find out cause i dont see anything under the carbs that says those numbers
i386
Re: Help Me Please
Some of the older engines have an ID plate in the housing underneath the carbs (not on the engine itself). The carbs themselves may have numbers on them but that will be just the carb part numbers. Just give it a good look over for any numbers you may find. There are so many similar looking engines that trying to ID it on site alone isn't reliable. Hang in there!
rudedude
Re: Help Me Please
Most of the Force motors had a plate rivited in side the motor houseing, twards the front . If you could get a part number off the power head and it was never changed out ,I would think you could get a year for it. Send me a couple good pictures and I will send them to a guy that may be able to tell you the year. hoghunter51@hotmail.com
Here in Mississippi if that little plate isnt there they look at it as a stolen motor, just gives them a reason to run as many checks as they can so they have somthing to do. Now thats just redneck thinking.:p
