Help me to re-ring my engine.
crispins
Run it for several RPM cycles and then shut if off and complexly cool several times to temper the pistons. Siezco pistons as soft till they temper up and make sure engine is at temp before running WOTeven after break-in
Can you explain further for me?
I will be taking it to the lake in a few days. What exactly should I do?
Just call Wiseco----Find the 1-800 number and find out what to do.
TurboJet
Hey crispins, the break in procedure is in the fsm i scanned for you..
I see you sniped one of my pics :p
Let us know how it turns out...
Go slow, take your time, you are almost there...
Faztbullet
. Does my outboard engine require any special piston adjustments or break-in when I use a Wiseco piston?
A. Outboard engines are very unique, in that the cooling system uses cold water from the lake or ocean. Because of this, the engine cylinder runs very cool as compared to many other engine types, and the piston does require more clearance to operate properly. Your Wiseco piston does have this additional clearance built into the design, and it is always best to follow the proper break in process. This is an extended process of heat cycling of the engine, and will ensure an extended piston life when followed. Refer to your OEM service manual for the proper break in for your engine, or you can also refer to our Marine catalog for general guidelines
Copied from WISECO....
