Help, My power tilt only works sometimes
Pooze
My power tilt on my 1976 Searay only will work for about 5 seconds then I have to wait 10-15 seconds before it will do anything again. It happens going up and down. It has a Mercruiser stern drive.
xltier
Re: Help, My power tilt only works sometimes
could be the motor is shot and its drawing to much current
mwolson1975
Just had the same problem on my OMC. Bearings were shot in the tilt motor. Replaced the motor and all works well now.
Ayuh,..........
Or,.......
It Could be as Simple as Bad Wiring..........
