help needed to fit a vortech to a non vortech boat
matthew daley
hi guys i have a chevy 262 fitted in my 21 ft renken but ive removed engine and its nackered i have a chance of a 1998 chevy blazer 252 vortech engine will everything swap over from original engine what needs changing? will it fit can i use the mpi wiring loom off the blazer hope you can help cheers mat:cool:
Kainon
Re: help needed to fit a vortech to a non vortech boat
I would read through previous posts ( probably 50 of them ) asking the same thing... most of the original engine will need to be swapped over, sure you can use the MPI but you'll have to get a computer tuned for Marine. $$$$$
Ayuh,.... Short answer is,... Nope....
What drive, 'n what Vintage are We talkin' 'bout,..??
matthew daley
hi its a 1991 omc cobra using a dog cutch type leg
Ayuh,... You could swap out the Long Blocks,...
'n buy an intake manifold to fit yer carb...
The electronics on the Blazer motor would be a Nightmare to make run, anywhere near Right....
matthew daley
hi ime a but slow on this am i right on saying that if i put my carb and manifold and distributor thats it? i realy need ure help other wise no fishing 4 me over hear the v6 is scarce as ****
Tommywalton
Yes there are tons of posts on here including the one i asked a week ago with no replies. I read before i asked because the posts are long and filled with a lot of garbage. Anyway i just did it and it runs like a raped ape!! Love it. If you go the long block route as i did these are the things you will need to address:
1 your flywheel/coupler should be ok if its a 91 omc. Will be a 1 piece set up and bolt right up
2 you will need an intake. You will also possibly have to fabricate mounting brackets for things that bolt to your intake as they wont match.
3 WATER PUMP! A vortec has no internal bypass, i learned this from a sbc forum as i got no answer on here about that question either. You must plumb up a bypass from existing water pump pipe thread plugged fitting up to the new vortec intake right below the t-stat housing.
4no mechanical fuel pump flange on a vortec. You will have to go electric. Better anyway IMO. Wire it up on a relay to an oil pressure switch i what i did.
5 the water pump also will not clear a vortec timing cover because of the long protruding bolt that a grinder will fix. Also plug the bypass hole on the old style pump with a 1/8 pipe plug.
Do these things an you will love your truck vortec
matthew daley
hi sounds like the anser i wanted to hear i got hole truck and a hole non vortech so iff i got this right i can just change my inlet manifolds over?
my engine is a 91 big coupler that bolts on to fly wheel bolts in the center
water pump can i use the vortech one?
already running a electric pump as mine failed and was easyier to fit a electric one
will my original distributor fit?
will my risers fit?
Tommywalton
Yes your distributor will fit
Yea your risers will fit
No your intake will not
No a vortec water pump wont fit. Length is diff. Also rotation is wrong also bc its serpentine. Use your old one. If i can help more let me know. I will answer your questions even if you ask twice
matthew daley
so what intake will i need and what do u mean by bypass pipe?
Tommywalton
Ok, what engine is in the 98? A 4.3? Or 5.7? It doesnt really matter either of those will need a carb intake. Edlebrock makes them. I chose a performer rpm for my 5.7 vortec. Im not sure about the bypass on a 4.3 what is your old engine?
matthew daley
hi its a 1991 4.3 262 non vortech 2bbl carb as to manifold i need a race manifold basically for a vortech?any part numbers would be gratfull only problem is where i live cant get post over hear very easy
matthew daley
hi been to look at the donor vechile it has a single point injection carb boddie will my carb bolt on to this
