Help to source Bravo 3 gimbal housing
saaristo
I need to change out the gimbal housing or sometimes called transom shield on my boat. I need only the part itself, without gimbal ring or trim cylinders and so on and my preference would be a used part in decent shape.
The boat comes from 2005 and it"s a Bravo 3. The part number should be 8M0096216 and the serial number of the existing one is 0W184540.
So if anyone knows some salvage yards or other place where to ask from let me know.
TIA
I usually have luck putting in a search on ebay
This one may be listed wrong alpha gen 2 and bravo ???
There are several on there reasonably (for boat parts priced)
saaristo
Thank you guys for input. I will consider all of those. At the same time, another potential candidate appeared - the only thing is seller is unsure about the part number and there is a word "diesel" on the sticker. Does anyone recon from the pictures whether it's the correct part?
