Hello,
I have a Johnson 50hp 50ESL73R outboard that has compression issues. The top cylinder is at 60psi and the bottom at 160psi. Any thoughts as to the problem?
Is it worth having the top or both cylinders bored out and to put the .030 o.s. rings in them?
It will start and run but I want it to run well.
If I do the cylinder pull, how much would it cost to have the boring done.. approximately?
Thanks
Thanks
