Help with adding power tilt and trim to 1978 1150 HP
arsenalpsu
Re: Help with adding power tilt and trim to 1978 1150 HP
I'd be careful purchasing that unit, it may work when it's not under load but leak or fail when lifting your engine. The motor is the most expensive part. Seals aren't that bad. As to it fitting your engine, do you have a manual? It should offer models with a t&t, start there to make sure.
That is not the correct PTT unit for your motor. Could it be adapted? I do not know.
