help with carburetor choice
N0 Luck
Was wondering your opinion on which one of these carbs to choose from Edelbrock 1409 or Holly 4150 :confused:
Thanks
wca_tim
Re: help with carburetor choice
either will work great depends on which you like better. that is... depending on what you're going to put it on???
N0 Luck
sorry, didnt think it mattered what its going on.
Its a new (2010) mercruiser 5.7 vortec (repowering from michigan motorz) pushing an old alpha one drive.
Ayuh,... Merc never used a Holley,... Bracketry will have to be built...
Merc does however use the Merc/ Weber/ Carter clone,..
Which is a carbon copy of the Edlebrock 1409...
mkast
The Mercruiser 888"s used a Holley two barrel.
Summit Racing carries the brackets for using a Holley four barrel on a Mercruiser engine.
achris
More fish than mountain goat
Merc stopped using Holleys (a long time ago) for a reason... Who am I to question their wisdom? Go with the 1409....
Chris.....
achris
GM produced a cheaper engine.
No, GM produced a better engine :D:D... Besides, GM/Ford didn't supply the carbs. I believe Mercury sourced them independently..
Chris.........
wca_tim
the 1409 is a good carb and a drop on. If you're a holley fan the holley will run just as well. for the larger 750 size, I would favor the holley...
