Help with Post??
AngelC
Does anyone know why I can't place a post in the engine forum, when I try I get this message. Does anyone know how I can fix this?:eek:
AngelC, you do not have permission to access this page. This could be due to one of several reasons:
Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
Log Out Home
Re: Help with Post??
The engine forum for your motor should not not be a problem unless you were trying to post in a locked thread or in any of the Adults Only Section ...... the i/o forum here should allow it http://forums.iboats.com/forumdisplay.php?f=21
a70eliminator
I've had that problem and had to refresh and sign in to the forum, but your posting here so that can't be the issue, probably like Bob VT says let us know.
QC
My thoughts were the same as a70's, Angel . . . give that a try and let us know if it helps.
AngelC
Ok guys...thank you, I will give it a try.:)
