mberliner1626
- Joined
- Sep 17, 2009
- Messages
- 28
I have a 1984 Grady Offshore with a merc 305 w/ alpha one.
I've located a running merc 350 (stock) from a donor boat. The casting ID is 14093638 - it's a 1987, 1 piece rear mail seal.
Will this be a direct drop in? without any changes/mods?
If this is a direct drop in. I'm going to hear it, see it run and conduct a compression test on the motor, prior to purchase. Is there anything else I should look for?
Thanks now for the help and any info...
