help with tach install
pappy3
OK here is what I have , 1992 88spl , it came with no tach and I need to know what color wires go where? I have peeled back the black outer coating
on the wire coming out of the control box. now what?:D pappy3
GlasV162
Re: help with tach install
The easiest way to hook it up is to buy the wiring harness; it plugs right into your control box; there are 3 wires on the other end that connect to the tach; I'm not sure which wires go where, but no doubt someone else here will chime in. If I remember right, that harness is about $30.00 but well worth it. Also, make sure you have your tach at the correct setting; should be 6p. Good luck.
da_ardvark
Gray wire-------pulse sender
Black wire------Ground
Purple wire-----Hot 12V DC running thru the key
Lodgepole
Right, and blue wire is dash lights (connect to navigation light sw)
