Hey Bondo
bluemist
You seem to have had a strong oppinion about the idea in my last post you answered. However you did not elaborate as to the reason my idea was dumb. Maybe you could let me know what damage I might be causing.<br /> AL
Re: Hey Bondo
If you wish to Clean the Carb,.........<br /><br />Take it Apart,+ Kit It......<br />Running Snake Oil Doesn't Clean the Clogged Passages,.... Disassembly,+ Compressed Air Will.....<br /><br />Pumping Gumout thru it Isn't going to Cure Anything,....... <br />And,... Like Boom stated,.... It's Not Designed to be Used in That Way...........<br /><br />It's Not a Fuel for Your Motor.........
