homemade transducer mount with pics
busted-bayliner
IMG00001-20120603-0234[1].jpgIMG00002-20120603-0234[1].jpgIMG00003-20120603-0236[1].jpgIMG00004-20120603-0236[1].jpg
just thought i would throw this out there if any one was low an cash as i am. I bought a used depth/fishfinder the was missing the transducer mount. i made a transducer mount with 2 stainless steel L brackets and some stainless steel bolts and nuts an a few washers total cost was about four dollars. The L brackets have holes in them already so it was a easy deal ill post a few pics later
jcupo6
Re: homemade transducer mount
Without pictures it never happened. ;)
busted-bayliner
82 views no one like my homemade mount darn :D
lrlima
looks like a good idea. will it hold in place when underway?
busted-bayliner
tested it today did very well
Looks good, well done.
dan t.
Good idea but you are still drilling holes in the transom, I would have epoxied it inside the hull for a shoot thru set up.
busted-bayliner
i was under the impression that that is a special transducer that shoots through the hull???
coastalrichard
If it reads and don't leak...call it good!
dan t.
any transducer will shoot thru hull if it is a solid fiberglass hull.the special is for a cored hull.
