honda 90 hp changing lower unit oil
frank2222
What would be the best lower unit oil to put in honda 90 hp. I put on the first 20 hours , the manuel saids to change it. But I don`t know what the best gear oil is. Thank you
Brewman61
Ensign
Re: honda 90 hp changing lower unit oil
Manual should also list the acceptable standard for lower unit lube for your motor. You won't go wrong using Honda's oil. Or any other brand that meets Honda's spec.
and the best part........ Honda manuals are free on-line!!!
